Author Topic: Setting beautifier settings for a project?  (Read 211 times)
jc44
  • Hero Points: 18
« on: April 14, 2021, 11:53:54 am »
Is there a way to set a beautifier set on a project (if not can I request it)?  Adaptive formatting gets linux kernel files tabs wrong even when I reset tab on the doc.  Setting beautifier to a linux set fixes this.  I asked this some years ago but clearly failed to pay attention to the answer.  I don't want to have to add files to the source tree.
Ta
  • Hero Points: 460
Re: Setting beautifier settings for a project?
« Reply #1 on: April 14, 2021, 02:30:26 pm »
At the moment, there's no way to do this without adding config files to your source tree. Beautifier Profile Overrides... (Tools>Beautifier>Beautifier Profile Overrides..) requires files underneath your source tree. Often you just need one config file at the root of some source tree.
