Author Topic: editing .md files shows popup  (Read 551 times)
ElJeffe
  • Hero Points: 7
« on: April 27, 2021, 08:12:52 am »
Everytime I type a space in an .md file, I get a popup with "Command ext-keys not found" message.
SlickEdit Pro 2020 (v25.0.1.0 64-bit)
OS: Linux
OS Version: Arch Linux
Kernel Level: 5.11.16-arch1-1
Build Version: #1 SMP PREEMPT Wed, 21 Apr 2021 17:22:13 +0000
Project Type: Gnuc
Language: .md (Markdown)
Encoding: UTF-8, no signature
Hotfixes:
/home/jef/.slickedit/25.0.1/hotfixes/hotfix_se2501_2_cumulative.zip (Revision: 2)
/home/jef/.slickedit/25.0.1/hotfixes/hotfix_se2501_6_cumulative.zip (Revision: 6)
ebbe
Re: editing .md files shows popup
« Reply #1 on: April 27, 2021, 11:34:33 am »
It may be caused by your setup somehow. I could not recreate this on my Linux installations as exemplified by this:
OS: Linux
OS Version: Ubuntu 20.04.2 LTS
Kernel Level: 5.4.72-microsoft-standard-WSL2
Build Version: #1 SMP Wed Oct 28 23:40:43 UTC 2020
Project Type: (Other)
Hotfixes:
/home/ebbe/.slickedit/25.0.1/hotfixes/hotfix_se2501_6_cumulative.zip (Revision: 6)
ElJeffe
  • Hero Points: 7
« Reply #2 on: April 27, 2021, 02:32:57 pm »
indeed, if I start with a clean config i do not have this. But I do not want to lose all my settings...
  • Hero Points: 484
« Reply #3 on: April 27, 2021, 02:39:12 pm »
Exit SlickEdit and try deleting your "25.0.1/vslick.sta" in your bad config. That might fix it.
ElJeffe
  • Hero Points: 7
« Reply #4 on: April 27, 2021, 03:01:36 pm »
no, deleting this file does not work.
  • Hero Points: 484
« Reply #5 on: April 27, 2021, 03:23:57 pm »
Post your 25.0.1/user.cfg.xml.  I suspect there is a key binding messing things up.
