Author Topic: Wildcards for projects.  (Read 1412 times)
  • Hero Points: 210
« on: May 07, 2021, 11:59:02 PM »
"Add tree" in Project opens a dialog showing a file tree, then
"SourceFiles" and "Exclude..."..
"Source Files" doesn't have the same set of patterns that Find in Files does, nor the same patterns that is in FileOpen.
Seems like it ought to. I should be able to select "C/C++ files" here.
Same for Exclude Files -- it should be prepopulated with <Binary>, <Default>, and whatever else normally shows up in Find In Files.
