Author Topic: slick stack on first run - Incorrect version tbcontrols.ex 3192  (Read 284 times)
  • Hero Points: 334
Slick upgraded my 25.0.2 config when I first ran it and reported an error
It gets this error every time I start it.
My config folder is here.
https://drive.google.com/file/d/1OgG_3wx5h-Bovle957Kp_OTxCKfqCw0o/view?usp=sharing
Stack trace written to file: C:\Users\graem\AppData\Local\Temp\vsstack.
 Incorrect version
tbcontrols.ex 3192 _tbGetUpdatedIconName(bbzoomin.svg)   p_window_id: 78   p_object: OI_EDITOR   p_name:
ToolbarCustomizationHandler.ex 2466 sc.controls.customizations.ToolbarCustomizationHandler.readMod(
   1:   ._typename()=sc.controls.customizations.ToolbarCustomizationHandler
   1:   .m-modFile=C:\GP\SlickConfig\26.0.0\userToolbars.xml
   1:   .m-elementName=Toolbar
   1:   .m-categoryName=Toolbars
   2:   18
   3:   5
   4:   ._typename()=sc.controls.customizations.UserModification
   4:   .m-command=
   4:   .m-caption=
   4:   .m-message=
   4:   .m-action=-1
   4:   .m-prev=
   4:   .m-next=
   p_window_id: 20
   p_object: OI_EDITOR
   p_name:
CustomizationHandler.ex 3629 sc.controls.customizations.CustomizationHandler.readModList(
   2:   18
   3:   2
   4:   Modifications
   5:   <empty>
   p_window_id: 20
   p_object: OI_EDITOR
   p_name:
CustomizationHandler.ex 3515 sc.controls.customizations.CustomizationHandler.readMods(
   2:   18
   3:   2
   4:   <empty>
   5:   <empty>
   6:   <empty>
   p_window_id: 20
   p_object: OI_EDITOR
   p_name:
CustomizationHandler.ex 3281 sc.controls.customizations.CustomizationHandler.readAndApplyFileChanges(
   2:   18
   p_window_id: 20
   p_object: OI_EDITOR
   p_name:
CustomizationHandler.ex 2850 sc.controls.customizations.CustomizationHandler.restoreChanges(
   p_window_id: 20
   p_object: OI_EDITOR
   p_name:
postinstall.ex 1293 postinstall:migrateMenuAndToolbarCustomizations()   p_window_id: 20   p_object: OI_EDITOR   p_name:
postinstall.ex 2283 postinstall:postTasks()   p_window_id: 20   p_object: OI_EDITOR   p_name:
postinstall.ex 2469 defmain()   p_window_id: 20   p_object: OI_EDITOR   p_name:
  • Hero Points: 465
Re: slick stack on first run - Incorrect version tbcontrols.ex 3192
« Reply #1 on: July 30, 2021, 02:36:51 pm »
I'll check this out later today.
  • Hero Points: 465
« Reply #2 on: July 30, 2021, 04:10:37 pm »
Do you have the VSLICKMACROS environment variable set?  It looks as if it is picking up a version of "updateobjs.e" from another installation.
pbrightly
  • Hero Points: 6
« Reply #3 on: July 30, 2021, 09:51:19 pm »
Ah, that's my exact worry in my other post. I want to run both my 2020 (v25) version and the v26 version, so I can switch back if a bug prevents me from doing my real job.  What are the recommendations for this?  Do I need to use a script to sent environment and launch each?
PS. I was surprised I still had SlickEdit2008 in the path.  :)
Anyway, I'm going to try running both v25  & v26.  My environment only contains the win\bin directory for 3 versions, as follows:
Path=C:\SlickEdit2021_b\win\
C:\SlickEdit2020\win\
c:\slickedit2008\win
PPS. And, it would seem the beta pulls from my existing installation. On first start of the beta I get "Unable to load module..." and it's trying to load my custom macros from my SlickEdit2020 directory. Cool, if it worked... but it says Incorrect Version.
« Last Edit: July 30, 2021, 10:16:40 pm by pbrightly »
  • Hero Points: 334
« Reply #4 on: July 30, 2021, 11:12:49 pm »
This command
_command void gp1234() name_info(',')
   say(get_env("VSLICKMACROS"));
gives me this
C:\Program Files\SlickEdit\V25-0-2\macros;plugin:\\
I didn't do this myself.  I have no VSLICK environment variables set.
I have sometimes wondered if I should have been using VSLICKMACROS though - so that slick can locate an error when I get a slick stack.
  • Hero Points: 334
« Reply #5 on: July 30, 2021, 11:23:20 pm »
My previous post was using 25.0.2.  When I do this in V26 I get this
C:\Program Files\SlickEdit\V26-0-0-1\macros;plugin:\\
  • Hero Points: 334
« Reply #6 on: July 31, 2021, 03:03:24 am »
If I start V26 with an empty config, then import all my settings and macros from 25.0.2, it runs without the tbcontrols.ex error.
  • Hero Points: 334
« Reply #7 on: July 31, 2021, 10:57:36 am »
As mentioned in my previous post, I imported my settings from 25.0.2  - I know this is technically unsupported but I've found that in app options -> Exit -> "save configuration"  - I previously had set to "prompt before saving on exit".  In V26 it has become "share config, save configuration immediately".
  • Hero Points: 467
« Reply #8 on: August 01, 2021, 04:50:32 pm »
This change is intentional. You can set it to something else after the import (or config upgrade).
