Author Topic: does _LineMarkerRemoveAllType clear markers from all open buffers  (Read 1543 times)
  • Hero Points: 340
Does  _LineMarkerRemoveAllType clear markers of the specified type from all open buffers - not just the active buffer.
 * Removes all line markers that have the specified type.
 * @param type Type of marker.
 * @appliesTo Edit_Window, Editor_Control
 * @categories Marker_Functions
extern void _LineMarkerRemoveAllType(int type);
  • Hero Points: 509
Re: does _LineMarkerRemoveAllType clear markers from all open buffers
« Reply #1 on: August 27, 2021, 02:19:52 pm »
Yes, if you want to remove line markers from the current buffer, use _LineMarkerRemoveType()
