Author Topic: PowerShell embedded inside markdown doesn't go to the 1st column  (Read 266 times)
spongyryno
« on: September 08, 2021, 03:16:26 pm »
If I'm editing a markdown file, and I create some embedded code, like:
```C++
As soon as I hit <ENTER> after the ```C++ line, it brings me to the first column, as expected.
If I do the same thing for almost any language, I get the same correct results.
However, if I do "PowerShell", it doesn't work. On <ENTER>, the cursor goes down 1 line, but stays in the exact same column. The syntax formatting appears to work, but this doesn't.
What am I doing wrong?
  • Hero Points: 470
Re: PowerShell embedded inside markdown doesn't go to the 1st column
« Reply #1 on: September 10, 2021, 12:31:47 am »
What version of SlickEdit are you running? I tried 25.0.2 and wasn't able to reproduce this.
spongyryno
« Reply #2 on: September 26, 2021, 04:16:03 am »
I'm using 25.0.2.
I wiped out my entire configuration directory to start clean. It's 100% reproducible. Just create a MD file consisting of the following:
```PowerShell
On the line with the word "PowerShell", go to the end of the line and hit <ENTER>. You'll be on the next line, but not in column 1. You'll be in column 14.
  • Hero Points: 470
« Reply #3 on: September 26, 2021, 12:24:34 pm »
Still can't reproduce this. Started with a clean config.
  • Hero Points: 470
« Reply #4 on: September 27, 2021, 05:34:44 pm »
Reproduced. Needed a different test case. I should have had you post a test file.
Added a hot fix for this. Will go in next hot fix build.
