Author Topic: Version control file status icons question  (Read 393 times)
rjpontefract
  • Hero Points: 7
« on: September 13, 2021, 08:28:30 pm »
Hi
Under options/version control/version control providers/git I have the "show file status on icons" option set to "on" under the "show file status" section.
Where am I supposed to be able to see the status?  My projects/workspace were imported from maven POM files and the files shown in the tree in the Projects tool window all just have plain text icons.  I expected to see the version control status on those icons.  The icons in the Files tool window in the Buffers tab also don't show the VCS status.
Where should I be looking to find the VCS status please?
SE 25.0.2.0 / 26.0.0.3 on Windows 10.
  • Hero Points: 141
Re: Version control file status icons question
« Reply #1 on: September 15, 2021, 03:41:01 pm »
It should show up there.  I will look into this.
rjpontefract
  • Hero Points: 7
« Reply #2 on: September 18, 2021, 08:47:22 am »
Hi Dan
Thanks for looking into this.  I've just opened a C/C++ Workspace that was imported from a Visual Studio 2019 solution and it doesn't show the VCS status either, so it's not just Maven/Java.
  • Hero Points: 141
« Reply #3 on: October 04, 2021, 06:27:31 pm »
Fixed for next version.
rjpontefract
  • Hero Points: 7
« Reply #4 on: October 04, 2021, 10:43:00 pm »
Hi Dan
That's great to hear, thanks.
rjpontefract
  • Hero Points: 7
« Reply #5 on: October 08, 2021, 05:31:12 pm »
Hi Dan
I installed VS26 RC1 and I still don't see the VCS status, which version was it fixed in please?
  • Hero Points: 141
« Reply #6 on: October 08, 2021, 05:35:47 pm »
It should work there.  I just tested it in an install from yesterday.  Can you PM me an email address and I'll send you a DLL with some debug in it?
rjpontefract
  • Hero Points: 7
« Reply #7 on: October 12, 2021, 09:45:04 pm »
Hi
I installed the 26.0.0.6 release and I still don't see VCS status on the project view icons in either Windows or Linux.
Is there anything I can provide to help you find the cause?
  • Hero Points: 141
« Reply #8 on: October 12, 2021, 09:57:13 pm »
I will email you something with some debug in it.  It will probably be tomorrow.
rjpontefract
  • Hero Points: 7
« Reply #9 on: October 17, 2021, 11:52:31 pm »
Hi Dan, did I miss something or have you just been busy?
  • Hero Points: 141
« Reply #10 on: October 17, 2021, 11:55:59 pm »
I haven't had a chance to get to this yet, but I'll send something this week.
