Author Topic: Double-tap doesn't select anymore  (Read 362 times)
at5dapa1
  • Hero Points: 22
« on: September 17, 2021, 12:42:12 pm »
Just discovered this that double-tap on the touchpad doesn't select. Double click on the left button still does the selection.
Tested with new config with an example C project and not able to select with double, tripple, 4xtap, etc.
SlickEdit Pro 2021 (v26.0.0.3 64-bit Qt5)
Serial number: FE78739_BETA
License type: Beta License
License expiration: 2021-10-10 03:00:00
License file: C:\ProgramData\slickedit\26\slickedit.lic
Build Date: September 1, 2021
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 16% Load, 5362MB/32475MB Physical, 6297MB/32475MB Page File, 4701MB/134217727MB Virtual
Screen Size: 1920 x 1080 (0 0 1920 1080)
Project Type: Gnuc
Language: .c (C/C++)
Encoding: ACP (1252)
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\26.0.0\ (non-removable drive,NTFS,96489MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\temp\26.0.0\ (non-removable drive,NTFS,96489MB free)
  • Hero Points: 507
Re: Double-tap doesn't select anymore
« Reply #1 on: September 17, 2021, 06:06:44 pm »
Already working on this one
https://community.slickedit.com/index.php/topic,18415.0.html
