Author Topic: More python highlighting weirdness  (Read 500 times)
  • Hero Points: 210
« on: September 20, 2021, 11:51:29 PM »
So I noticed that in a *.py file highlighting (shift-arrow selection highlights) was offset.
If I close and reopen the file, then it is fixed.
If I close the workspace and reopen so Slick restores the *.py file, then I get this problem.
I attached a ZIP file with a sequence of screenshots showing this problem.
Start with the cursor at the top of the file, then the progression, pressing Ctrl+Shift+RightArrow several times.
