Author Topic: Slick-C stack enabling version control  (Read 819 times)
rjpontefract
  • Hero Points: 9
« on: October 08, 2021, 05:22:40 PM »
Using RC1 on macOS 11, I enabled git version control for my workspace in Version Control/System Setup.  I set default, workspace and project to git and then clicked on the wrench icon to go to the options.  I got the following stack:
Stack trace written to file: /tmp/vsstack.rjp
 Procedure -SccCloseProject not found
vc.ex 22128 _vc_select_form_apply()   p_window_id: 300   p_object: OI_FORM   p_name: _vc_select_form
DialogTransformer.ex 437 se.options.DialogTransformer.callFunction(
   1:   ._typename()=se.options.DialogEmbedder
   1:   .m-caption=System Setup
   1:   .m-panelHelp=Use these settings to enable version control support and to specify configuration information and preferences. <b>If you do not see your system, please contact SlickEdit support</b>.
   1:   .m-systemHelp=Version Control Setup Options
   1:   .m-picture=vcsetup.svg
   1:   .m-form=_vc_select_form
   1:   .m-wid=300
   1:   .m-xmlIndex=6818
   1:   .m-langID=
   1:   .m-inheritsFromForm=
   1:   .m-vcProviderID=
   1:   .m-width=5853
   1:   .m-height=1257
   1:   .m-options=(null)
   1:   .m-functions._typename()=se.options.FormFunctions
   1:   .m-functions.GetStaticSearchTags=27793
   1:   .m-functions[1]=0
   1:   .m-functions[2]=27785
   1:   .m-functions[3]=27788
   1:   .m-functions[4]=27786
   1:   .m-functions[5]=0
   1:   .m-functions[6]=0
   1:   .m-functions[7]=0
   1:   .m-state=
   1:   .m-controls=(null)
   2:   27793
   3:   -1
   4:   -1
   5:   -1
   p_window_id: 284
   p_object: OI_LABEL
   p_name: ctllabel1
DialogEmbedder.ex 1257 se.options.DialogEmbedder.apply(
   1:   .m-wid=300
   1:   .m-xmlIndex=6818
   1:   .m-langID=
   1:   .m-vcProviderID=
   1:   .m-width=5853
   1:   .m-height=1257
   1:   .m-state=
   p_window_id: 284
   p_object: OI_LABEL
   p_name: ctllabel1
OptionsConfigTree.ex 1427 se.options.OptionsConfigTree.apply(
   1:   ._typename()=se.options.OptionsConfigTree
   1:   .m-treeHandle=282
   1:   .m-frameHandle=275
   1:   .m-helpHandle=274
   1:   .m-currentPanelWid=300
   1:   .m-currentCaption=Version Control > System Setup
   1:   .m-currentTreeIndex=24
   1:   .m-relations._typename()=se.options.RelationTable
   1:   .m-relations.m-tableHASHTAB (55 items)
   1:   .m-relations.m-table:[tree15]=361
   1:   .m-relations.m-table:[xml6485]=7
   1:   .m-relations.m-table:[xml379]=17
   1:   .m-relations.m-table:[tree25]=6827
   1:   .m-relations.m-table:[xml413]=20
   1:   .m-relations.m-table:[tree18]=391
   1:   .m-relations.m-table:[tree12]=7267
   1:   .m-relations.m-table:[xml6812]=9
   1:   .m-relations.m-table:[xml6818]=24
   1:   .m-relations.m-table:[xml403]=19
   1:   .m-relations.m-table:[xml6827]=25
   1:   .m-relations.m-table:[tree5]=3510
   1:   .m-relations.m-table:[xml5477]=6
   1:   .m-relations.m-table:[tree20]=413
   1:   .m-relations.m-table:[xml7117]=10
   1:   .m-relations.m-table:[xml371]=16
   1:   .m-relations.m-table:[tree24]=6818
   1:   .m-relations.m-table:[xml7249]=11
   1:   .m-relations.m-table:[tree17]=379
   1:   .m-relations.m-table:[tree19]=403
   1:   .m-relations.m-table:[tree9]=6812
   1:   .m-relations.m-table:[xml3510]=5
   1:   .m-relations.m-table:[tree22]=814
   1:   .m-relations.m-table:[xml814]=22
   1:   .m-relations.m-table:[xml11]=1
   1:   .m-relations.m-table:[xml391]=18
   1:   .m-relations.m-table:[tree0]=7
   1:   .m-relations.m-table:[tree1]=11
   1:   .m-relations.m-table:[xml1334]=3
   1:   .m-relations.m-table:[tree2]=895
   1:   .m-relations.m-table:[xml7]=0
   1:   .m-relations.m-table:[tree13]=16
   1:   .m-relations.m-table:[xml3297]=4
   1:   .m-relations.m-table:[xml16]=13
   1:   .m-relations.m-table:[xml6735]=8
   1:   .m-relations.m-table:[tree26]=6885
   1:   .m-relations.m-table:[tree16]=371
   1:   .m-relations.m-table:[xml0]=0
   1:   .m-relations.m-table:[tree6]=5477
   1:   .m-relations.m-table:[tree23]=821
   1:   .m-relations.m-table:[tree3]=1334
   1:   .m-relations.m-table:[tree7]=6485
   1:   .m-relations.m-table:[xml7267]=12
   1:   .m-relations.m-table:[xml361]=15
   1:   .m-relations.m-table:[tree14]=353
   1:   .m-relations.m-table:[xml821]=23
   1:   .m-relations.m-table:[xml655]=21
   1:   .m-relations.m-table:[tree21]=655
   1:   .m-relations.m-table:[xml353]=14
   1:   .m-relations.m-table:[tree4]=3297
   1:   .m-relations.m-table:[xml895]=2
   1:   .m-relations.m-table:[xml6885]=26
   1:   .m-relations.m-table:[tree8]=6735
   1:   .m-relations.m-table:[tree11]=7249
   1:   .m-relations.m-table:[tree10]=7117
   1:   .m-parser._typename()=se.options.OptionsXMLParser
   1:   .m-parser.m-xmlHandle=14
   1:   .m-parser.m-xmlFile=options.xml
   1:   .m-parser.m-defaultFile=1
   1:   .m-parser.m-templates=<empty>
   1:   .m-parser.m-propTemplates=(null)
   1:   .m-parser.m-includedHASHTAB (64 items)
   1:   .m-parser.m-included:[391]=1
   1:   .m-parser.m-included:[3532]=1
   1:   .m-parser.m-included:[5337]=1
   1:   .m-parser.m-included:[4138]=1
   1:   .m-parser.m-included:[4]=1
   1:   .m-parser.m-included:[5199]=1
   1:   .m-parser.m-included:[814]=1
   1:   .m-parser.m-included:[7249]=1
   1:   .m-parser.m-included:[7276]=0
   1:   .m-parser.m-included:[6485]=1
   1:   .m-parser.m-included:[3297]=1
   1:   .m-parser.m-included:[7122]=1
   1:   .m-parser.m-included:[841]=1
   1:   .m-parser.m-included:[16]=1
   1:   .m-parser.m-included:[7293]=1
   1:   .m-parser.m-included:[900]=1
   1:   .m-parser.m-included:[6490]=1
   1:   .m-parser.m-included:[3303]=1
   1:   .m-parser.m-included:[11]=1
   1:   .m-parser.m-included:[3510]=1
   1:   .m-parser.m-included:[5477]=1
   1:   .m-parser.m-included:[5379]=1
   1:   .m-parser.m-included:[6735]=1
   1:   .m-parser.m-included:[4407]=1
   1:   .m-parser.m-included:[3524]=1
   1:   .m-parser.m-included:[7117]=1
   1:   .m-parser.m-included:[4597]=1
   1:   .m-parser.m-included:[379]=1
   1:   .m-parser.m-included:[4843]=1
   1:   .m-parser.m-included:[361]=1
   1:   .m-parser.m-included:[6740]=1
   1:   .m-parser.m-configParser._typename()=se.options.OptionsConfigurationXMLParser
   1:   .m-data._typename()=se.options.OptionsData
   1:   .m-data.m-panelWIDsHASHTAB (2 items)
   1:   .m-data.m-panelInfoHASHTAB (2 items)
   1:   .m-data.m-panelInfo:[6818]._typename()=se.options.DialogEmbedder
   1:   .m-data.m-panelInfo:[6818].m-options=(null)
   1:   .m-data.m-panelInfo:[6818].m-functions._typename()=se.options.FormFunctions
   1:   .m-data.m-panelInfo:[6818].m-controls=(null)
   1:   .m-data.m-panelInfo:[11]._typename()=se.options.CategoryHelpPanel
   1:   .m-navigator._typename()=se.options.OptionsHistoryNavigator
   1:   .m-navigator.m-historyARRAY (2 items)
   1:   .m-navigator.m-history[0]._typename()=se.options.HistoryNode
   1:   .m-navigator.m-history[1]._typename()=se.options.HistoryNode
   1:   .m-modifiedHASHTAB (1 items)
   1:   .m-modified:[6818]._typename()=se.options.ModifiedNode
   2:   1
   3:   1
   p_window_id: 284
   p_object: OI_LABEL
   p_name: ctllabel1
optionsxml.ex 24379 _options_tree_form._ctl_apply.lbutton_up()   p_window_id: 284   p_object: OI_LABEL   p_name: ctllabel1
  • Hero Points: 153
Re: Slick-C stack enabling version control
« Reply #1 on: October 08, 2021, 05:25:36 PM »
Thanks for the report!
  • Hero Points: 153
« Reply #2 on: October 08, 2021, 07:21:55 PM »
Fixed for next build.  If you PM me an email address I'll send you the fixed macro so you can get things setup.
