Author Topic: Is the Qt5 Linux version of 26.0.0.6 available?  (Read 375 times)
rjpontefract
  • Hero Points: 7
« on: October 18, 2021, 08:05:13 pm »
Hi
Is there an option to download the Qt5 Linux version of 26.0.0.6 (64-bit)?
  • Hero Points: 483
Re: Is the Qt5 Linux version of 26.0.0.6 available?
« Reply #1 on: October 18, 2021, 08:51:58 pm »
« Last Edit: October 18, 2021, 09:47:59 pm by Clark »
rjpontefract
  • Hero Points: 7
« Reply #2 on: October 18, 2021, 08:54:39 pm »
Thanks! (I had to copy and paste the link though, as it points to sestandard_26000006_linux64qt5.tar.gz not se_26000006_linux64qt5.tar.gz)
« Last Edit: October 18, 2021, 08:56:46 pm by rjpontefract »
  • Hero Points: 483
« Reply #3 on: October 18, 2021, 09:48:55 pm »
Oops  Fixed it. Link should work now.
patrickkox
  • Hero Points: 6
  • Debian GNU/Linux user
« Reply #4 on: October 22, 2021, 07:55:43 pm »
Is there a reason why this version is not just made available through the "Registered Products" page ?
That would make it a lot easier since now with every update someone needs to come here and ask for the download link.
  • Hero Points: 483
« Reply #5 on: October 22, 2021, 08:38:32 pm »
The Qt5 installers need more testing. The Qt5 version seems to be working for the hand full of beta testers that have tried it. It is unknown if the Qt5 installation will run on all of our customers Linux installations. We had to build this installer on a slightly newer version of Linux and it references more Linux library code. Also, we don't know whether there will be Window manager issues. In the future, we will either make both installers available from the website or just switch to the Qt5 version. No dates set.
patrickkox
  • Hero Points: 6
« Reply #6 on: October 23, 2021, 08:12:51 am »
Well in that case, I can confirm that it appears to work correctly on my Debian Stable (Bullseye) system.
