Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Drag-n-drop seems broken on Linux (again)
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Drag-n-drop seems broken on Linux (again) (Read 771 times)
JeffB
Senior Community Member
Hero Points: 14
on:
October 27, 2021, 02:26:20 pm »
This happened in the Beta as well. Wonder if the bug snuck back in (v26.0.0.6)?
Logged
SlickEdit Team Member
Hero Points: 509
Re: Drag-n-drop seems broken on Linux (again)
Reply #1 on:
October 27, 2021, 03:16:04 pm »
32-bit, 64-bit, 64-bit Qt5, or ARM Linux?
Logged
JeffB
Hero Points: 14
Reply #2 on:
October 27, 2021, 04:32:27 pm »
SlickEdit Pro 2021 (v26.0.0.6 64-bit Qt4)
Logged
Hero Points: 507
Reply #3 on:
October 28, 2021, 03:45:33 pm »
I can't reproduce any problems. What are you seeing?
Logged
Hero Points: 509
Reply #4 on:
October 28, 2021, 03:48:08 pm »
Which Linux distribution and version? Have you tried the Qt5 version of v26?
Logged
JeffB
Hero Points: 14
Reply #5 on:
October 28, 2021, 05:34:46 pm »
Kubuntu 18.04. I just tried the Qt5 version and it does the same thing. Behavior is same as:
https://community.slickedit.com/index.php/topic,18349.0.html
When you click to drag, it just undoes the current highlighting and starts a new selection.
Logged
Hero Points: 507
Reply #6 on:
October 28, 2021, 08:40:58 pm »
I just tried my Kubuntu 18.0.4 VM with v26.0.0.6 64-bit Qt4 and could not reproduce this problem.
Please try a default config:
Code:
[Select]
vs +new -sc /tmp/new-config-dir&
Logged
JeffB
Hero Points: 14
Reply #7 on:
October 28, 2021, 08:56:55 pm »
My bad...somewhere along the way the config setting got turned off. I don't know how (it's been on for years). Anyway, it's working now. Thanks!
Logged
Hero Points: 507
Reply #8 on:
October 28, 2021, 09:36:35 pm »
Glad you figured it out. SlickEdit has so many settings even we can't keep track of them all.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
