Author Topic: Color coding profile 'Ruby': Invalid type 'bqbackslash'  (Read 600 times)
  • Hero Points: 132
« on: October 28, 2021, 02:20:13 pm »
With 26.0.0.6 linux 64bit qt4, out of nowhere the attached box appeared. I never use Ruby.
  • Hero Points: 511
Re: Color coding profile 'Ruby': Invalid type 'bqbackslash'
« Reply #1 on: October 28, 2021, 04:16:57 pm »
Easiest fix is to remove if from user.cfg.xml.
Some config upgrade in the past must have failed.
