Author Topic: Issues in build window after manually sshing to build machine there  (Read 5691 times)
  • Hero Points: 132
Look for se_build_window_issue.tgz in support and see the README file as well as the other files.
  • Hero Points: 486
Re: Issues in build window after manually sshing to build machine there
« Reply #1 on: November 02, 2021, 08:03:31 pm »
Try turning on "Show VSLICKERRORPATH in build window" (Tools>Options>.Editing>General).  So far, all I can tell is that this is messing up the cursor location. I'm still looking into this.
Changing this option won't effect catting this log file. Your logfile already has output based on hiding the VSLICKERRORPATH.
« Last Edit: November 02, 2021, 08:42:43 pm by Clark »
  • Hero Points: 486
« Reply #2 on: November 03, 2021, 01:31:29 am »
I have found a bug that can occur if you hide certain build window lines like VSLICKERRORPATH. This will be fixed in 26.0.1. It's rare but your example is the perfect test case for it. Thanks
I'm not sure if this is the only problem you are hitting. After you turn on "Show VSLICKERRORPATH in the build window", post if you are still having any problems.
  • Hero Points: 132
« Reply #3 on: November 03, 2021, 12:44:07 pm »
Setting "Show VSLICKERRPATH in build window" seems to resolve the issue so far, haven't seen the issues again. I'll keep using this setting and see if anything new pops up.
Thanks!
  • Hero Points: 132
« Reply #4 on: November 08, 2021, 01:53:33 pm »
It happened again this time with "Show VSLICKERRPATH" set to "ON".
Look for logbug.tgz on support. See the README file there for more information about the 2 different log files I provided.
  • Hero Points: 486
« Reply #5 on: November 09, 2021, 01:06:03 pm »
Still looking into this one. At the moment, it looks like it has something to do with processing of backspace under certain circumstances. You have a ton of backspaces in this test case.
  • Hero Points: 486
  • Hero Points: 132
« Reply #7 on: November 17, 2021, 07:02:09 pm »
Thanks Clark! Downloading now and will install it. I will let you know if there are still issues.
  • Hero Points: 486
« Reply #8 on: November 17, 2021, 07:38:03 pm »
Thanks again for the really good test case
  • Hero Points: 132
« Reply #9 on: December 06, 2021, 02:45:54 pm »
It happened again even with the installer you provided.
Look for buildlog.tgz on support. See its README file.
  • Hero Points: 486
« Reply #10 on: December 07, 2021, 06:01:46 pm »
These problems are due to long lines messing up scrolling. I've fixed this for v26.0.1. Hard to say if there are any other problems going on but I can't reproduce any more problems with my fix.
  • Hero Points: 132
« Reply #11 on: December 07, 2021, 06:28:25 pm »
Are your fixes in 26.0.1 on top of what you provided in the special installer (post in this thread dated Nov 17)? There are more fixes besides that special installer?
If not then I'm also running with your same fixes yet the problem reproed.
  • Hero Points: 486
« Reply #12 on: December 08, 2021, 01:50:11 am »
The fixes you already have are merged into 26.0.1. You don't have the long line handling fix.
  • Hero Points: 132
« Reply #13 on: December 14, 2021, 03:48:46 pm »
I still see the issue in 26.0.1.
I uploaded to support see: buildlog-26.0.1.tar.gz
  • Hero Points: 486
« Reply #14 on: December 14, 2021, 10:44:15 pm »
So far, I'm not able to reproduce these problems. There must be a very specific boundary condition occurring.
Are you able to reproduce this problem by doing this in the process buffer:
cat se_build.log
