Author Topic: Find/replace dialog box won't open via control keys or menu  (Read 2032 times)
mktschudi
« on: November 17, 2021, 05:53:26 PM »
OK in v25.0.2.0 64-bit, suddenly stopped in v26.0.0.6 64-bit. Reboot didn't help. Is there a reset?
  • Hero Points: 153
Re: Find/replace dialog box won't open via control keys or menu
« Reply #1 on: November 17, 2021, 07:39:25 PM »
Try running "tbResetAll" (without the quotes) on the SlickEdit command line (depending on emulation, press Esc, or click at the bottom, to the left of the line/column/etc information).
mktschudi
« Reply #2 on: November 17, 2021, 07:52:47 PM »
Worked perfectly. Thank you very much, Dan!
  • Hero Points: 153
« Reply #3 on: November 17, 2021, 07:54:23 PM »
Glad to help.
rygaard
« Reply #4 on: January 02, 2023, 06:50:25 PM »
I had the same problem.  The solution posted by @Dan worked perfectly.
  • Hero Points: 539
« Reply #5 on: January 02, 2023, 11:26:18 PM »
You can also reset the tool window layout here:
Window>Reset Window Layout
Can't remember what version of SlickEdit added this menu item.
