Author Topic: FindInFiles: Look In <WorkSpace>  (Read 300 times)
  • Hero Points: 203
« on: November 17, 2021, 08:23:57 pm »
I've been using "<Workspace>" lately as it helps me when I alternate between multiple copies of a project.
However, when I do a FindInFiles like this there is a long delay before the search apparently starts running.
Presumably, it is iterating all the project files?
In this workspace there are several wildcard projects - a total of 2818 files.
  • Hero Points: 482
Re: FindInFiles: Look In <WorkSpace>
« Reply #1 on: November 17, 2021, 08:57:54 pm »
Are the files remote or on your local hard disk?
  • Hero Points: 203
« Reply #2 on: November 17, 2021, 11:26:38 pm »
All files are local.
  • Hero Points: 482
« Reply #3 on: November 18, 2021, 12:57:04 am »
Have you set the "Tag Files Directory" for the workspace? I ask this because the wildcard cache doesn't work if you've set this. This will be fixed in 26.0.1. If you've set this I suspect this is the problem.
Post a picture of the Find in Files settings.
I tested a remote workspace with 3500 files. For me there was no delay and this remote directory is crazy slow. I only tested with one project with wildcards.
How many projects are there with wildcards?
If you change your workspace to only contain one project with wildcards (try largest set of files), does that help much?
  • Hero Points: 203
« Reply #4 on: November 19, 2021, 06:11:41 pm »
I have not set TagFilesDirectory.
There are 5 projects and all are wildcards.
There are a few randomish files too - accidentally added to some project when creating files with File->New.
FiF pauses 8 seconds after I hit "Find" before something appears to happen.
Procmon confirms - no file access during the long pause.
Find all "PerformanceProblems", "<Workspace>", "*", Exclude: "<Default Excludes>;rest2.x\"
Failed to open: C:\src\....\blah1
Failed to open: C:\src\....\blah2
Failed to open: C:\src\....\blah3
Failed to open: C:\src\....\blah4
Total found: 0     Matching files: 0     Total files searched: 2838
  • Hero Points: 482
« Reply #5 on: November 19, 2021, 06:59:24 pm »
Thanks for the picture. All the time is being spent processing the excludes. I'll check if there is anything we can do to speed this up.
The work around is to remove the excludes and specify specific file extensions instead of '*'
« Last Edit: November 19, 2021, 08:51:10 pm by Clark »
  • Hero Points: 482
« Reply #6 on: November 19, 2021, 09:02:13 pm »
Optimized this type of exclude processing case for 26.0.1. Should take about 1 second instead of 8.
