Author Topic: v26 regression : syntax coloring for php code in html mode  (Read 320 times)
jcelle
  • Hero Points: 5
« on: November 23, 2021, 09:05:06 am »
Hello,
Today I spotted a regression in syntax coloring for php code using html mode.
I am attaching screenshots of the same file displayed in v25 and v26 to illustrate.
In v26 screenshot I show where the problem starts :
'{preview}',I confirm that by removing the ending the '}' the problem disappears.
« Last Edit: November 23, 2021, 09:07:52 am by jcelle »
  • Hero Points: 484
Re: v26 regression : syntax coloring for php code in html mode
« Reply #1 on: November 24, 2021, 02:30:57 am »
This is fixed in the first v26 hot fix. Should be available very soon.
jcelle
  • Hero Points: 5
« Reply #2 on: November 24, 2021, 06:51:43 am »
Sounds great. Thanks.
