Author Topic: Issue with SCC version control, after setup no "Version Control" menu items.  (Read 1385 times)
mlong
Hi,
After upgrading SlickEdit from V25 to V26 (32 bit) and setting up the version control to SCC the “Version Control” menu item and the equivalent context right click show no items. Hopefully the image attached shows how I have this setup in V26 where I understand this area has had changes since V25 which previously worked ok.
Regards
  • Hero Points: 153
Let me look into that.  Thanks for the detailed report.
  • Hero Points: 153
This is a project you were already using in v25, correct?
mlong
Yes this project works fine in V25 using the SCC version control interface.
  • Hero Points: 153
I was able to reproduce this.
mlong
Thanks that's great, I can work around it.. but would you know when a fix is likely to be available?
  • Hero Points: 153
Not too long for this.  The icons in the project menu may have to be 26.0.1
  • Hero Points: 153
I have a potential fix.  Could you PM me your email address?
  • Hero Points: 153
This has been addressed and will be in the next hotfix and 26.0.1.
