Author Topic: 26.0.1 : toolbar is lost  (Read 489 times)
jcelle
  • Hero Points: 5
« on: December 20, 2021, 01:39:04 pm »
Hello, this seems one the recurrent things we lose upon each update: my toolbar has been reset.
Is there anyway I can grab the proper config from the previous files as I would like to have exactly what I had ?
Thanks.
  • Hero Points: 481
Re: 26.0.1 : toolbar is lost
« Reply #1 on: December 21, 2021, 03:44:21 pm »
Can you zip up the 26.0.0 portion of your configuration directory, and post that here?  I only need the top-level files, nothing in subdirectories.  I can then try to debug the migration process.  It looks like your Version Control toolbar did not restore, correct?  I have that toolbar docked (and modified), and it migrated correctly for me, so I'll need to try to reproduce it from your test case.
jcelle
  • Hero Points: 5
« Reply #2 on: January 14, 2022, 01:28:03 pm »
Thanks Dennis - sorry I did not check back earlier : well I put things back in place manually, we'll see next time...
  • Hero Points: 481
« Reply #3 on: January 14, 2022, 01:51:04 pm »
Because the SlickEdit configuration directory is versioned, your 26.0.0 directory should still be there.  26.0.1 makes a copy of its own.
