Author Topic: Slick-C error in SVN history diff  (Read 1010 times)
ahkevin
« on: January 03, 2022, 01:41:24 pm »
Version Control -> History diff on xxxx.c
right click on left or right source window.
Stack trace written to file: C:\Users\Kevin\AppData\Local\Temp\vsstack.
 Control -ctlfile1label referenced but does not exist
diffedit.ex 3979 diffedit:bothSidesHaveVersions()   p_window_id: 328   p_object: OI_EDITOR   p_name: _ctlfile1
diffedit.ex 4181 diffedit:edit_window_rbutton_up()   p_window_id: 328   p_object: OI_EDITOR   p_name: _ctlfile1
diffedit.ex 10492 diffedit:_EditControlEventHandler()   p_window_id: 328   p_object: OI_EDITOR   p_name: _ctlfile1
diffedit.ex 12078 _diff_form._ctlfile1.range_first_nonchar_key-all_range_last_nonchar_key()   p_window_id: 328   p_object: OI_EDITOR   p_name: _ctlfile1
dlgeditv.ex 7260 show(-modal -xy  _history_diff_form,@22574,,0)   p_window_id: 32   p_object: OI_EDITOR   p_name:
svc.ex 15066 svc_history_diff(.c,,,0)   p_window_id: 32   p_object: OI_EDITOR   p_name:
 Control -ctlfile2-readonly referenced but does not exist
diffedit.ex 4164 diffedit:edit_window_rbutton_up()   p_window_id: 324   p_object: OI_EDITOR   p_name: _ctlfile2
diffedit.ex 10492 diffedit:_EditControlEventHandler()   p_window_id: 324   p_object: OI_EDITOR   p_name: _ctlfile2
diffedit.ex 12091 _diff_form._ctlfile2.range_first_nonchar_key-all_range_last_nonchar_key()   p_window_id: 324   p_object: OI_EDITOR   p_name: _ctlfile2
svc.ex 15066 svc_history_diff(xxxx.c,,,0)   p_window_id: 32   p_object: OI_EDITOR   p_name:
  • Hero Points: 144
Re: Slick-C error in SVN history diff
« Reply #1 on: January 04, 2022, 03:50:45 pm »
I can't reproduce this so far.  Do you have 26.0.1?
ahkevin
« Reply #2 on: January 07, 2022, 01:28:14 am »
yes
  • Hero Points: 144
« Reply #3 on: January 07, 2022, 03:22:55 pm »
I overlooked something, my mistake.  I will be looking into this.
  • Hero Points: 144
« Reply #4 on: January 12, 2022, 02:16:22 pm »
This is fixed for the next hotfix.
ahkevin
« Reply #5 on: January 27, 2022, 09:27:58 am »
hotfix 3 was partly fix this issue, left window is ok, right window also caused Slick-C stack.
diffedit.ex 4177 diffedit:edit_window_rbutton_up()   p_window_id: 404   p_object: OI_EDITOR   p_name: _ctlfile2
diffedit.ex 10505 diffedit:_EditControlEventHandler()   p_window_id: 404   p_object: OI_EDITOR   p_name: _ctlfile2
diffedit.ex 12104 _diff_form._ctlfile2.range_first_nonchar_key-all_range_last_nonchar_key()   p_window_id: 404   p_object: OI_EDITOR   p_name: _ctlfile2
dlgeditv.ex 7260 show(-modal -xy  _history_diff_form,@19451,,0)   p_window_id: 142   p_object: OI_EDITOR   p_name:
svc.ex 15234 svc_history_diff(xxxx.c,,,0)   p_window_id: 142   p_object: OI_EDITOR   p_name:
  • Hero Points: 144
« Reply #6 on: January 27, 2022, 04:02:59 pm »
My apologies for missing that.  I'll have a fix shortly.
  • Hero Points: 144
« Reply #7 on: January 27, 2022, 05:19:14 pm »
This will be in the next hotfix. It is a single file file fix, so if you would like me to send it to you just PM me an email address.
ahkevin
« Reply #8 on: January 28, 2022, 11:02:50 am »
PM sent
ahkevin
« Reply #9 on: January 29, 2022, 03:07:52 am »
it works, thanks
