Author Topic: Bogus undo-past-save  (Read 382 times)
  • Hero Points: 206
« on: January 10, 2022, 09:51:24 pm »
After doing Undo in Minifind, doing Undo in the buffer complains about Undo Past Save.
Open: C:\Program Files\SlickEdit Pro 26.0.1\macros\adaptiveformatting.e
Then:
1. Ctrl+H and if needed, Alt+C to be case sensitive.
2. Find: indent (Seems to be important to actually change this field when trying to repro).
3. Replace: Indent
4. Alt+A (replace all)
5. Close mini find (by clicking "X")
6. Ctrl+H to open Minifind again
7. Ctrl+Z - to undo the Find part of minifind (appears to do nothing - correct)
8. <ESC> to close Minifind.
9. Ctrl+Z (to under the replace done in step 4).
Bug:
You are about to undo past previous save.
Continue?
Cancel   &Yes   &No
  • Hero Points: 485
Re: Bogus undo-past-save
« Reply #1 on: January 11, 2022, 02:06:24 am »
Reproduced
  • Hero Points: 485
« Reply #2 on: January 11, 2022, 06:12:18 pm »
Hot fix added for this
