Author Topic: How to go to type definition of an 'auto' in C++?  (Read 326 times)
  • Hero Points: 132
« on: January 12, 2022, 09:23:03 pm »
Lets say I have the below code in C++:
class FuncReturnType
FuncReturnType function()
auto var = function()
// I want to go put my cursor in 'var' below and do something similar to push-tag that takes
// me to the definition of the type of 'var' - i.e. it takes me to 'class FuncReturnType'
newfunction(var, xxx)
I would like to go to the definition of the type that 'var' is.
Is there something similar to 'push-tag' that will take me to the definition of the type of 'var' instead of where 'var' is defined?
See my comment above newfunction() in the code above for more clarity.
  • Hero Points: 480
Re: How to go to type definition of an 'auto' in C++?
« Reply #1 on: January 12, 2022, 10:07:43 pm »
There isn't, but it is a really good idea.  I am going to add an FR for this for the next release (and get to work on it soon).
A couple bits that are already there:
  • Ctrl+Alt+,   (symbol-info-help) -- shows comments and evaluates return type (showing "Evaluated type: ..." after comments.  You can do this for most symbols.
  • Preview Tool Window -- "Document > <language> Options... > Context Tagging" has an option for the preview tool window to show the evaluated type for the symbol under the cursor (again right after the comments)
  • Mouse over symbol info help -- again there is an option under "Document > <language> Options... > Context Tagging" to show the evaluated return type for the symbol under the mouse.
  • Ctrl+Dot (push-tag) -- sometimes what you need is pretty close under your finger tips, just jump to var, then jump to it's type, etc.
  • Dot -- similar example, type "." after var, and you get Auto-list members, cursor down, pick one from the list, then click the green arrow on its comments to jump to the definition.
  • Hero Points: 132
« Reply #2 on: January 12, 2022, 10:18:47 pm »
Thanks so much Dennis!
