Author Topic: Preview not working when source is floating  (Read 320 times)
at5dapa1
  • Hero Points: 22
« on: January 14, 2022, 07:27:22 am »
Not sure if it's duplicate, but when I have the document not in the main MDI but floating then the Preview doesn't work.
SlickEdit Pro 2021 (v26.0.1.0 64-bit Qt5)
Serial number: WB951378
License file: C:\ProgramData\slickedit\26\slickedit.lic
Build Date: December 13, 2021   (State file: January 10, 2022)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 21% Load, 6899MB/32475MB Physical, 7989MB/32475MB Page File, 4632MB/134217727MB Virtual
Screen Size: 1920 x 1200 (0 0 1920 1200), 1920 x 1080 (1920 0 1920 1080), 1920 x 1080 (-1920 0 1920 1080)
Language: No file open
Encoding: No file open
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\26.0.1\ (non-removable drive,NTFS,91394MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\config\26.0.1\ (non-removable drive,NTFS,91394MB free)
Hotfixes:
D:\tools\totalcmd\Tools\dev\SlickEdit\config\26.0.1\hotfixes\hotfix_se2601_2_cumulative.zip (Revision: 2)
  • Hero Points: 480
Re: Preview not working when source is floating
« Reply #1 on: January 14, 2022, 02:14:55 pm »
That is intentional.  When docked, a preview window will operate on the current active editor window in the same group.  If floating, a preview window will operate on any current active editor window.  This behavior holds true for several tool windows (Defs, Class, Highlight, etc).  If you were to dock another instance of the Preview tool window with your floating editor window, it would keep up with that window.
