Author Topic: Is there a size limitation on a macro  (Read 1801 times)
seeplusplus
« on: January 14, 2022, 08:14:50 pm »
I am trying to load a macro built on another machine. But, if the size is above 3800 lines, I get "Runtime Error Position Found".
Is there a fix for that?
SlickEdit 2012 (v17.0.2.0 64-bit)
Serial number: FWB922119
Licensed number of users: 750
License server: 27100@license-wan-sd1
Build Date: August 09, 2012
Emulation: Visual C++ 6
OS: Windows 8 x64
OS Version: 6.02.9200
Memory: 52% Load, 10606MB/20300MB Physical, 14056MB/41804MB Page File, 37553MB/134217727MB Virtual
Shell Info: C:\WINDOWS\system32\cmd.exe /q
Screen Size: 1920 x 1080
Project Type: Cpp
Language: .e (Slick-C)
  • Hero Points: 512
Re: Is there a size limitation on a macro
« Reply #1 on: January 14, 2022, 09:27:43 pm »
The size limitations have been increased in more recent versions of SlickEdit.
The other option is to break the macro down into sub-modules.
If the module contains a lot of string data, you should consider loading the data from a data file, because lots of strings can lead to using a lot of macro byte code space.
  • Hero Points: 341
« Reply #2 on: January 14, 2022, 10:41:28 pm »
You could try splitting in two and #including one of them into the other.  I don't know if this would work.  It depends where slickedit applies the limit.
You could also pre-process the file and look for lines ending in semi-colon  - then join the next line to the current line by removing the line ending  -  CR LF.  You can use the slick join_line command for this.
e.g. record a macro to search for semi-colon [whitespace] at the end of a line then call join_line.
  • Hero Points: 512
« Reply #3 on: January 14, 2022, 10:45:37 pm »
There is no limit on the number of lines.  In fact, the error you get when a Slick-C macro is to large is "code size too large", indicating the amount of byte code generated exceeds the limit.
#include works like a C++ #include, so that is not going to cut the code size any.  But, if you break it into two modules, you can have the main module #import the other module.
