Author Topic: Word Wrap While Typing - but not with tab?  (Read 817 times)
  • Hero Points: 210
« on: January 19, 2022, 07:30:21 pm »
When I enable this and type, it wraps as expected.
But, <TAB> inserts spaces and doesn't cause any wrapping.
Why not?
Can I get it to?
I tried this with PlainText and Slick-C documents.
Also, is there a way to get wrapping to indent the body of a paragraph (more or less) than the first line?
For example:
The quick Returns VF_??? constant defined in "slick.sh" which indicates
    the current storage format of a variable (often not the same as
    declaration type).  We DO NOT recommend you use this function because
    its return values are likely to change with the next version of
This function is currently only intended for use by the developers of
    SlickEdit and Slick-C&reg;.
