Author Topic: The fastest "else if" in the West  (Read 2206 times)
  • Hero Points: 509
« on: January 26, 2022, 04:27:48 pm »
Did you know you can add an else-if clause in brace-oriented languages with one keypress?
Try this:
            if ( condition_one ) {
                // type a close brace on the next (blank) line
            } else {
You will be left with this:
            } else if ( | ) {
            } else {
Did you really want just a close brace?  Easy, hit Undo:
            } else {
Note:  If you do not already have the "else" clause, you will be prompted whether you want to add an "else if" or an "else".
