Author Topic: c/c++ auto-complete performance  (Read 881 times)
ahkevin
« on: March 14, 2022, 01:37:37 pm »
I noticed that SE lag when I work on a large c/c++ project( > 10K files).
I searched the forums and found a topic had discussed the issue.
https://community.slickedit.com/index.php?action=post;quote=70715;topic=18007.0;last_msg=70727
When will this feature be implemented? Will it be in V27?
  • Hero Points: 512
Re: c/c++ auto-complete performance
« Reply #1 on: March 14, 2022, 09:00:52 pm »
A large portion of the auto-complete core engine code was re-written in C++ for version 26.  The language-specific code still needs to be rewritten, and nothing is thread-safe yet (really can not make much thread-safe until the language-specific code is thread-safe).  I do not know if this will be completed for v27 or not.
Frequently performance issues with C++ trace back to preprocessing making code parse incorrectly and gums up the gears.  Sometimes it's just too many layers of type-inference and template expansion.  Really have to investigate and come up with reproducible cases for specific issues that come up laggy.
ahkevin
« Reply #2 on: March 15, 2022, 03:38:33 am »
It is same issue in large C project, such as linux kernel.
« Last Edit: March 15, 2022, 03:40:12 am by ahkevin »
  • Hero Points: 512
« Reply #3 on: March 15, 2022, 12:07:16 pm »
Are you seeing it as an everywhere issue, or in certain cases?
One thing you could do since you have a larger project, is to dial down some of the Auto-Complete sub-word matching options to be less aggressive.
ahkevin
« Reply #4 on: March 15, 2022, 02:01:44 pm »
It is an everywhere issue in my opinion.
Yes,You're right. It does ease the issue, but it's not complete, sometimes there are still laggy.
