I have some global aliases set up that will add headers to my C file. There's "chead" which adds a header to the top of a .c file, "hhead" that adds a header to the top of a .h file, and "ghead" which adds a group header within a C file. I've been using these macros for years with no problem until the last time I updated the software. Now the chead macro gives me "cmse_check_address_range" rather than the C file header ("hhead" and "ghead" still work fine). I've checked the options and the C file header is still being defined in the global options. "chead" is not defined in the local options. Why is this happening and how do I get it back to the original macro definition?
