Author Topic: Ctrl-F11 and Ctrl-F12 (Macro record/run) behavior change  (Read 380 times)
Mr68360
  • Hero Points: 3
« on: June 04, 2022, 06:59:57 pm »
Previous to v26, when I recorded a "temporary" keystroke macro using Ctrl-F11, I was able to immediately "run" the macro with Ctrl-F12.
When I record with 26.0.x using Ctrl-F11, when I attempt to invoke it with Ctrl-F12 (without stopping the recording with a second Ctrl-F11), the previously recorded macro runs.  If I press Ctrl-F12 a second time, then the desired recorded macro runs.  Seems execution needs to be handled differently in record-macro-end-execute().
  • Hero Points: 501
Re: Ctrl-F11 and Ctrl-F12 (Macro record/run) behavior change
« Reply #1 on: June 05, 2022, 01:53:40 am »
Reproduced. We will look into this.
  • Hero Points: 501
« Reply #2 on: June 05, 2022, 01:11:42 pm »
Hotfix added for this
Mr68360
  • Hero Points: 3
« Reply #3 on: June 05, 2022, 07:10:52 pm »
Thank you, Clark.  Looking forward to it.
