Author Topic: VS 26.0.2.1 Diff Lockup  (Read 1056 times)
PiezonTM
  • Hero Points: 8
« on: June 08, 2022, 08:43:38 pm »
If I attempt to diff the two attached files (simple CSV files) VS locks up and stops responding.
SlickEdit Pro 2021 (v26.0.2.1 64-bit Qt4)
Serial number: -----
License file: /opt/slickedit-pro2021/bin/slickedit.lic
Build Date: May 2, 2022
Emulation: CUA
OS: Linux
OS Version: Ubuntu 18.04.6 LTS
Kernel Level: 5.4.0-113-generic
Build Version: #127~18.04.1-Ubuntu SMP Wed May 18 15:40:23 UTC 2022
Window Manager: GNOME Shell
Display manager: /usr/sbin/gdm3
Memory: 97% Load, 33254MB/34239MB Virtual
Shell Information: "/opt/slickedit-pro2021/bin/secsh" -i
Screen Size: 2560 x 1440, 2560 x 1440, 2048 x 1152
Language: .xml (XML)
Encoding: UTF-8, no signature
Installation Directory: /opt/slickedit-pro2021/
Configuration Directory: /home/----/.slickedit/26.0.2/
Migrated from: /home/----/.slickedit/26.0.1/
Spill File: /tmp/$slk.----.22270
  • Hero Points: 146
Re: VS 26.0.2.1 Diff Lockup
« Reply #1 on: June 09, 2022, 12:12:11 am »
What options are you using for the diff?
PiezonTM
  • Hero Points: 8
« Reply #2 on: June 09, 2022, 02:06:55 pm »
I tried with both files selected as "files" and I also tried with both buffers being "buffers". I have attached screenshot of the diff options.
  • Hero Points: 146
« Reply #3 on: June 09, 2022, 02:18:31 pm »
I still can't reproduce a hang so far.  I noticed one of the files you have as a .log file but I think that what I extracted was still csv.  I just renamed it.  I tried your options.  Can you send me your user.cfg.xml?
PiezonTM
  • Hero Points: 8
« Reply #4 on: June 10, 2022, 05:07:28 pm »
You are correct, the screenshot was with a different file but that was really meant to show the settings--that file locks up as well. I just reran the test with the files I sent you and it reproduces 100% of the time.  Sorry for the confusion
  • Hero Points: 146
« Reply #5 on: June 10, 2022, 06:20:19 pm »
I am still not able to get it.  Are you prompted for Source Diff?
PiezonTM
  • Hero Points: 8
« Reply #6 on: June 10, 2022, 06:41:10 pm »
No. Nothing at all pops up and I cannot close VS using any graphical mean. I have to kill the process.
  • Hero Points: 146
« Reply #7 on: June 10, 2022, 06:55:41 pm »
Can you check to see if the end of line characters match?  I get prompted about that, but it does work.  I'm wondering if it is hanging before it gets that far.
I'm trying 26.0.2 on  Ubuntu 18, which should be close to your setup.
PiezonTM
  • Hero Points: 8
« Reply #8 on: June 10, 2022, 08:20:35 pm »
They are different line endings indeed. The one file was generated from Windows (CRLF) and the other was Linux (LF). I saved the CRLF as LF and retried. When they were both LF it still locked up VS. I do not event get the dialog asking to convert line endings.
  • Hero Points: 503
« Reply #9 on: June 10, 2022, 10:40:57 pm »
Try a clean config:
vs +new -sc /tmp/testconfig&
and use the default diff options to diff these files. Dan knows diff better than I do but I've been trying various diff options on Linux and haven't been able to reproduce a hang either.
  • Hero Points: 146
« Reply #10 on: June 12, 2022, 07:41:49 pm »
Try a clean config:
I think this is the best thing to try right now.  I haven't been able to reproduce it either.
PiezonTM
  • Hero Points: 8
« Reply #11 on: June 13, 2022, 12:53:33 pm »
I tried the suggested command and it failed the same way.
  • Hero Points: 146
« Reply #12 on: June 13, 2022, 04:25:58 pm »
Are you using vsdiff, or running it from inside the editor?  I'm guessing inside the editor from the screenshots.
If I send you a macro with some debug, can you send me the output?
« Last Edit: June 13, 2022, 04:28:16 pm by Dan »
PiezonTM
  • Hero Points: 8
« Reply #13 on: June 13, 2022, 07:57:48 pm »
I am diffing using the editor. I can try whatever you need.
  • Hero Points: 146
« Reply #14 on: June 13, 2022, 08:02:18 pm »
Can you PM me an email address?  Thanks.
