Author Topic: alias expansion: %\c placeholder broken  (Read 455 times)
jcelle
  • Hero Points: 5
« on: August 03, 2022, 07:05:24 PM »
Steps to reproduce:
- trigger an alias expansion that contains several %\c placeholders (see screenshot)
- as soon as one key is pressed after less than a second all markers vanish : it is no longer possible to TAB navigate to expected %\c placeholders
Please let me know if you need further details.
« Last Edit: August 03, 2022, 07:09:28 PM by jcelle »
  • Hero Points: 513
Re: alias expansion: %\c placeholder broken
« Reply #1 on: August 03, 2022, 08:54:15 PM »
Reproduced. Occurs when outline update kicks in
jcelle
  • Hero Points: 5
« Reply #2 on: August 04, 2022, 05:30:47 AM »
Good to hear. Do you think there is a way to disable outline until fix comes out ?
Found : there is an option to turn outline off  :) and you are right, bug is then no longer present with outline off.
« Last Edit: August 04, 2022, 05:50:20 AM by jcelle »
  • Hero Points: 515
« Reply #3 on: August 04, 2022, 02:48:03 PM »
Fixed for next beta.
