Author Topic: Build markers sidebar gets dirty on buffer scrolling  (Read 469 times)
at5dapa1
  • Hero Points: 22
« on: August 04, 2022, 11:25:24 am »
Noticed that when build buffer scrolls automattically or manually then the markers "sidebar" gets dirty, probably keeps old markers' locations?
  • Hero Points: 496
Re: Build markers sidebar gets dirty on buffer scrolling
« Reply #1 on: August 04, 2022, 01:12:19 pm »
You need to turn off Spell check while typing. Tools>Options>Languages>SlickEdit Languages>Process>General.
SlickEdit only spell checks lines of text when they are displayed to you. During a build, many pages never become visible on the screen even though they are added to the build window. Once you scroll all lines of text into view, it is all spell checked. That's why you see added red for misspelled words.
  • Hero Points: 489
« Reply #2 on: August 04, 2022, 02:52:38 pm »
Just a helpful tip here.  If you move your mouse over the document overview bar, it will give you a tooltip about any markup you see.  This would have helped you see that it was spell check.
at5dapa1
  • Hero Points: 22
« Reply #3 on: August 04, 2022, 07:57:39 pm »
Spell check OFF on Tools>Options>Languages>SlickEdit Languages>Process>General did the trick, thanks!
Didn't know it's spelling (yes I enabled it globbaly) I thought they are error markers.
Nut now when I tried to see the tooltips pointed by Dennis found another minor glitch: I had SE on the right-screen before building, then moved it on the left-screen and when scrolled over the sidebar the tips appeared on the right screen...  ;)
  • Hero Points: 489
« Reply #4 on: August 04, 2022, 08:59:58 pm »
Does this also happen in your configuration with the minimal tooltips ?
at5dapa1
  • Hero Points: 22
« Reply #5 on: August 05, 2022, 05:36:46 pm »
I thought that it was because SE was initialy on the right screen and it happened after I moved on the left screen.
But when I tried today, SE already oened on left screen but those "scrollbar" tooltips are still on the right.
What does it mean "minimal tooltips"? How do I achieve that, some special settings?
The other tooltips (tagging, toolbar, etc) they appear ok (on the screen where SE is)...
  • Hero Points: 489
« Reply #6 on: August 05, 2022, 05:48:15 pm »
Auto-correct.  Grrr.  I was asking about the MINIMAP tooltips.
at5dapa1
  • Hero Points: 22
« Reply #7 on: August 05, 2022, 05:58:29 pm »
Minimap tooltips are on the correct screen (they follow SE on its screen): didn't know I have such tooltips (had to enable: right-click: Show -> Tooltip) :-)
  • Hero Points: 489
« Reply #8 on: August 23, 2022, 02:43:54 pm »
I have not been able to reproduce the issue with the document overview bar tooltips appearing on the wrong screen.  The closest I came was if I had a tooltip up and then hit Windows+Shift+Left to flip SlickEdit over to the other screen, the existing tooltip would hang out on the original screen until SlickEdit noticed things had changed.  The next time the tooltip came up, it was always in the correct location.
I am assuming from what I can make out of the screen shot that you are on Windows (don't know what version).  To reproduce this I'd probably have to replicate exactly the steps you did on the same platform and OS release.
at5dapa1
  • Hero Points: 22
« Reply #9 on: August 24, 2022, 05:06:18 pm »
Tried again with a clean config "D:\tools\totalcmd\Tools\dev\SlickEdit\core\27.0.0\win\vs.exe -sc "D:\tools\totalcmd\Tools\dev\SlickEdit\temp"" and unfortunately the same.
SlickEdit Pro 2022 (v27.0.0.1 64-bit Qt5)
Serial number: FE78739_BETA
License type: Beta License
License expiration: 2022-10-20 03:00:00
License file: C:\ProgramData\slickedit\27\slickedit.lic
Build Date: August 1, 2022
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 8% Load, 2899MB/32464MB Physical, 4466MB/32464MB Page File, 4571MB/134217727MB Virtual
Screen Size: 1920 x 1200 (0 0 1920 1200), 1920 x 1200 (-1920 0 1920 1200)
Project Type: Gnuc
Language: .c (C/C++)
Encoding: ACP (1252)
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\27.0.0\ (non-removable drive,NTFS,187615MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\temp\27.0.0\ (non-removable drive,NTFS,187615MB free)
Spill File: C:\Users\work\AppData\Local\Temp\$slk.5200 (non-removable drive,NTFS,186967MB free)
After starting with the clean config, the only change was in "Tools > Options > Languages > SlickEdit Languages > Process > General" to set the Spell check while typing = True. Then created a demo project and built it and the tooltips apear in the far right of the main screen (in left is screen 2, in right is screen 1 = the main display).
Windows 10 Pro 21H2, x64.
at5dapa1
  • Hero Points: 22
« Reply #10 on: September 03, 2022, 07:18:06 am »
Just a headsup that this happens for me with beta2 too. Not a major issue though, just a funny feature  ;)
Seems that possition of the tooltip is always the extreme right, but the width depends on the SE's width as shown in pictures here, maybe it helps
SlickEdit Pro 2022 (v27.0.0.2 64-bit Qt5)
Build Date: August 31, 2022   (State file: September 1, 2022)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 11% Load, 3688MB/32464MB Physical, 5537MB/32464MB Page File, 4645MB/134217727MB Virtual
Project Type: Gnuc
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\27.0.0\ (non-removable drive,NTFS,163192MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\temp\27.0.0\ (non-removable drive,NTFS,163192MB free)
  • Hero Points: 489
« Reply #11 on: September 06, 2022, 11:25:12 am »
I'll give it another try later this week.  But so far I have not been able to reproduce the problem.
  • Hero Points: 489
« Reply #12 on: September 20, 2022, 05:18:55 pm »
I am still unable to reproduce this.  I even set up a virtual machine with exactly the screen size and locations that you have.  Are you using any sort of display manager utility (like Nvidia RTX Desktop Manager)?
at5dapa1
  • Hero Points: 22
« Reply #13 on: September 20, 2022, 07:46:23 pm »
No Nvidia or other window Managers. I just tested on my son's desktop (I copy-pasted my SE install there) and it happens there too, unfortunately the config is quite similar (Win10 but Home vs Pro, less RAM, another Nvidia card, dual monitors, etc) so maybe it's not so good test:
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 13% Load, 2097MB/16122MB Physical, 3494MB/16122MB Page File, 4764MB/134217727MB Virtual
Screen Size: 1920 x 1080 (0 0 1920 1080), 1920 x 1080 (1920 0 1920 1080)
Project Type: Gnuc
Installation Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\core\27.0.0\ (non-removable drive,NTFS,164834MB free)
Configuration Directory: D:\tools\totalcmd\Tools\dev\SlickEdit\config\27.0.0\ (non-removable drive,NTFS,164834MB free)
  • Hero Points: 489
« Reply #14 on: September 20, 2022, 08:26:04 pm »
FINALLY.  Reproduced it.  It only appears to happen for the document overview bar for editor controls embedded in tool windows.
