Author Topic: Life Error Profiles for Java?  (Read 416 times)
florihupf
« on: August 05, 2022, 09:16:53 am »
Hi there,
Love the Life Error Profiles feature.  Esp., since I now can configure the colors for the highlights. :-)
One thing that I miss is that I would love to be able to use Life Error Profiles for .java files as well, but the Option is not available in the Tools -> Languages -> Application Languges menu.
I think I read somewhere that is because there is internal support for something similar.  That is all good, but I need to run this external linter tool and it works for all other languages.
Any chance to enable this?
Thank you!!
Florian
  • Hero Points: 147
Re: Life Error Profiles for Java?
« Reply #1 on: August 05, 2022, 12:47:08 pm »
Right now, there isn't a setting you can change to get that for Java.  I left that in place mainly because the Java implementation does a lot of setup to try to avoid JVM startup costs.  I didn't want to lose that, but it didn't occur to me to just support both and let the user select which one to use.
I'll take a look and see if I can add that.  May be able to get it for beta 2.
florihupf
« Reply #2 on: August 08, 2022, 01:06:00 pm »
Hi Patrick,
That would be super awesome! :-)
  • Hero Points: 147
« Reply #3 on: August 12, 2022, 07:23:48 pm »
This is in for beta 2.  The Java language options will now have a Live Errors, where you can add a profile for your linter.  Enabling Live Errors for Java disables the builtin compiler integration in favor of the user defined profiles.
florihupf
« Reply #4 on: August 16, 2022, 12:56:01 pm »
Awesome! Thanks a bunch!
