Author Topic: Cannot Ctrl-click in "Files/Buffers"  (Read 433 times)
PiezonTM
  • Hero Points: 8
« on: August 09, 2022, 02:07:47 PM »
Unable to select more than one file unless you use the shift-click. The ctrl-click does not allow you to select more than one file.
Just tried again and found it sometimes selects a file if I click enough
SlickEdit Pro 2022 (v27.0.0.1 64-bit Qt4)
Serial number: FE17393_BETA
License type: Beta License
License expiration: 2022-10-19 20:00:00
License file: /opt/slickedit-pro2022beta1/bin/slickedit.lic
Build Date: August 1, 2022
Emulation: CUA
OS: Linux
OS Version: Ubuntu 18.04.6 LTS
Kernel Level: 5.4.0-122-generic
Build Version: #138~18.04.1-Ubuntu SMP Fri Jun 24 14:14:03 UTC 2022
Window Manager: GNOME Shell
Display manager: /usr/sbin/gdm3
Memory: 97% Load, 47871MB/48854MB Virtual
Shell Information: "/opt/slickedit-pro2022beta1/bin/secsh" -i
Screen Size: 2560 x 1440, 2560 x 1440, 2048 x 1152
Project Type: Single file project - Gnuc
Language: .cpp (C/C++)
Encoding: UTF-8, no signature
Installation Directory: /opt/slickedit-pro2022beta1/
Configuration Directory: /home/tmoore/.slickedit/27.0.0/
Migrated from: /home/tmoore/.slickedit/26.0.3/
Spill File: /tmp/$slk.tmoore.5048
  • Hero Points: 153
Re: Cannot Ctrl-click in "Files/Buffers"
« Reply #1 on: August 09, 2022, 02:10:26 PM »
There is an issue with Ctrl+Click here, but Shift+Click can be used as a workaround.  I'll look into this.
  • Hero Points: 153
« Reply #2 on: August 10, 2022, 05:30:03 PM »
This is fixed for Beta 2. Thanks for the report!
