Author Topic: Scrollbar and Document Overview Bar  (Read 276 times)
  • Hero Points: 210
« on: August 12, 2022, 06:45:41 pm »
#1 ScrollBar Size:
Maybe just a number instead of small, tiny, huge, etc.
The number being the actual width in pixels?
#2
Document OverView bar has lots of settings, but no setting for its size.
#3
Show Block Matching: I can't seem to get this to do anything.
What blocks are matched and shown?
#4: Annotation overview popup as less than ideal title text -- looks like html.
A bit of decoding and formatting would be better.
#5: When there are multiple marks at the same place in the overview you cannot pick which popup to show. BreakPoint seems to take precedence over others.
  • Hero Points: 494
Re: Scrollbar and Document Overview Bar
« Reply #1 on: August 13, 2022, 10:04:04 pm »
Just a quick note.  I'll looking into all these scroll related questions next week (and beyond).  Thanks for all the feedback!
  • Hero Points: 494
« Reply #2 on: August 18, 2022, 10:01:15 pm »
#1 Scrollbar Size:
I was trying to keep it consistent with the nomenclature used for Toolbar and Tool Window buttons.  Either way, people are going to try different sizes until they find what they like.
#2 Document overview bar size options.
True, however, it does get larger along with the scroll bar for larger scroll bar sizes.
There are only two sizes though.  If enough people want a wider document overview bar in combination with a narrow scroll bar, I'll consider it for a future release.  In practice, the height of the document overview bar is more of a limiting factor than it's width.
#3 Show Block Matching
If you have Tools > Options... > Editing > General > Highlight Matching blocks enabled, then the block matching will show a marker for the beginning and end of a block.  For an example, try putting your cursor on the open brace of a large function body.
#4 Annotation mouse-over popup.
You are absolutely right.
#5 Multiple marks
Also true.
I will look into #4 and #5.
