Author Topic: B3: LiveDiff doesn't udpate  (Read 441 times)
  • Hero Points: 210
« on: September 23, 2022, 08:04:34 PM »
I have livediff enabled and it seems to correctly highlight differences.
Then from outside slickedit I commit the changes to git.
Slickedit doesn't update the livediff highlights --- all the pre-commit highlights stay, even when I continue editing the file.
I have to toggle live diff off then on to get a proper refresh.
  • Hero Points: 153
Re: B3: LiveDiff doesn't udpate
« Reply #1 on: September 23, 2022, 08:08:22 PM »
I'll have to think about that.  I don't want to check the status too often.
  • Hero Points: 210
« Reply #2 on: September 23, 2022, 10:04:05 PM »
Are you checking status per file, or per directory?
  • Hero Points: 153
« Reply #3 on: September 26, 2022, 01:17:12 PM »
I think I need to check the last version in the repository vs the last version in the repository when Live Diff last happened.
