Author Topic: Git blame editor window should be RO  (Read 947 times)
  • Hero Points: 210
« on: September 26, 2022, 07:16:09 PM »
Since the title bar still shows the original filename, it would be best for this buffer to be RO to avoid accidentally editing and losing changes.
  • Hero Points: 153
Re: Git blame editor window should be RO
« Reply #1 on: September 26, 2022, 07:29:07 PM »
I don't see how it can get out of svc_get_annotated_buffer without turning it read only, unless it fails to get the file.
  • Hero Points: 153
« Reply #2 on: September 27, 2022, 12:41:42 PM »
Can you send us your user.cfg.xml?
  • Hero Points: 210
« Reply #3 on: September 27, 2022, 10:21:30 PM »
Well, I cannot repro that problem now.
However, I found something else :-)
#1: Do Git-blame, then Ctrl-Z (undo).
The buffer is now empty
#2: Do Git-blame, then Save
It complains the file is RO and prompts with "do you wish to: ..."
Of course, the file doesn't really exist.
When you select "Make file writable", then hit OK:
SlickEdit Pro
Unable to update read only attribute for: Untitled 2022-09-27 1517
OK
