Author Topic: Find Symbol window  (Read 955 times)
joecar
  • Hero Points: 9
  • engineer/gearhead
Find Symbol window
« on: December 19, 2022, 07:21:20 pm »
27.0.1.0
I see that the Find Symbol window requires the following sequence:
1. open the Find Symbol window,
2. type in the symbol to Search For,
3a. click on the occurrence I want,
3b. click on the Goto Definition button (at bottom right)
3c. close the Find Symbol window.
In previous SE versions, at step 3a you could double click on the occurrence, and you would be taken there and the Find Symbol would close automatically (i.e. you did not need to do steps 3b and 3c). I find that this does not work any more, making it very cumbersome.
Is there an option/setting that I missed.
Thanks.
« Last Edit: December 19, 2022, 07:22:57 pm by joecar »
  • Hero Points: 509
Re: Find Symbol window
« Reply #1 on: December 19, 2022, 08:32:14 pm »
FWIW, after step (2), you could just cursor down to the symbol you want in the list, then hit Enter.  There does appear to be an issue with this, sometimes you have to hit Enter twice.  I'll add a fix for that to the next cumulative hot fix for 27.0.1.
I can not seem to reproduce a problem with double-click though.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #2 on: December 20, 2022, 10:37:10 am »
Dennis, so double click works for you...?
Is there an option setting that I need to change...?
  • Hero Points: 509
« Reply #3 on: December 20, 2022, 01:13:03 pm »
It does.  I only tested on macOS, but this should not be a platform-specific issue.  Nevertheless, what platform are you seeing this issue on?
The only setting that could be involved is whether you have the Find Symbol tool window configured to dismiss on Escape.  Tools > Appearance > Tool Windows > Find Symbol > (x) Esc dismisses floating window
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #4 on: December 22, 2022, 08:04:32 pm »
Win 11.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #5 on: December 22, 2022, 08:07:15 pm »
I already have the ESC dismiss set for the Find Symbol window.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #6 on: December 22, 2022, 08:14:36 pm »
In post #1 above, I should have clarified that that double clicking on the symbol does not take me to its definition/declaration (so I have to click the Goto Definition button at bottom right of Find Symbol window).
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #7 on: December 22, 2022, 08:15:37 pm »
i.e. double clicking on the symbol does not work anymore.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #8 on: January 06, 2023, 06:44:05 pm »
Same is happening in hotfix 2.
Double clicking on the symbol in the Find Symbol window results does not work anymore.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #9 on: January 19, 2023, 09:16:51 pm »
More info:
This happens when using a touch pad (i.e. on a laptop).
I plugged in a mouse and when using the mouse this does not happen.
  • Hero Points: 509
« Reply #10 on: January 20, 2023, 02:27:08 pm »
Let me know if the fix Clark gave you for clicking on a text selection also fixes this issue.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #11 on: January 23, 2023, 09:40:30 am »
Dennis,
Clark's fix does not appear to fix this.
In my previous messages here, where I said "click"/"clicking", I actually meant "tap"/"tapping".
Double tapping still exhibits the issue.
I found I have to click down on the touchpad (i.e. the touchpad is also a button) twice (i.e. the double click) and the proper behaviour occurs (goto symbol definition, close Find Symbol window).
« Last Edit: January 23, 2023, 09:46:21 am by joecar »
  • Hero Points: 507
« Reply #12 on: January 24, 2023, 08:12:48 pm »
I couldn't reproduce your double click problem with soft taps on my touch pad. I suggest you slow down your double-click speed. Attached is a picture of the "Additional mouse options" in Windows.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #13 on: January 24, 2023, 08:25:20 pm »
Clark, Thanks, I'll try that.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #14 on: January 24, 2023, 08:26:36 pm »
Hi Clark,
I find that if I physically slow down my double taps, then it behaves correctly.
