Author Topic: <Default Excludes> add *.vpwhistu but still there in "Replace in Files"  (Read 1403 times)
  • Hero Points: 132
I added *.vpwhistu to "Default Excludes" in Tools->Options->Editing->Search, made <Default Excludes> equal to:
<Binary Files>;*.vpwhist*
Now when I do "Find in Files" the searched text (which is present in the .vpwhistu file) is no longer shown in the search results (it was in the search results when *.vpwhist* was not in <Default Excludes>).
However when I then go to "Replace in Files", and keep using my <Default Excludes>, it does now find the term in the .vpwhistu file and is asking to replace it, even though *.vpwhist* is in <Default Excludes> and it doesn't show in "Find in Files" results - it still asks to replace it.
I'm using 27.0.1 on Linux x64.
« Last Edit: December 23, 2022, 03:54:59 AM by rowbearto »
  • Hero Points: 535
Reproduced. Not a new bug.
  • Hero Points: 535
Added hot fix for this. You can work around this by specifying a literal list of extensions.
