Author Topic: Selecting line from block matching popup  (Read 313 times)
jnairb
  • Hero Points: 11
« on: January 04, 2023, 03:10:54 pm »
I was playing with the block matching mentioned in the recent Advanced Block Matching tip. If I select a line (i.e. click on line number) from the block matching popup, my cursor is moved to that line, but the file is not repositioned, so the cursor may be off screen. Is there an option to reposition the file also?
  • Hero Points: 509
Re: Selecting line from block matching popup
« Reply #1 on: January 04, 2023, 04:39:41 pm »
Reproduced.  I'll look into putting in a fix.
  • Hero Points: 509
« Reply #2 on: January 10, 2023, 10:59:58 pm »
This will be fixed in the next revision of the cumulative hot fix for 27.0.1.
jnairb
  • Hero Points: 11
« Reply #3 on: January 10, 2023, 11:02:03 pm »
Thanks!
