Author Topic: SE cannot find the python interpreter  (Read 351 times)
ebbe
« on: January 27, 2023, 02:01:38 pm »
When I try to debug a python script, SE throws up a message box with the text:
No python interpreter found at C:\Python311\python.exe.
while I can do this in the Build pane:
C:\Users\ebbek\projects\tbdtools\test>which python
C:\Python311\python.EXE
See also the attached picture.
SE Info:
SlickEdit Pro 2022 (v27.0.1.0 64-bit Qt5)
Serial number: WL461730
License file: C:\ProgramData\slickedit\27\slickedit.lic
Build Date: December 7, 2022   (State file: January 3, 2023)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 74% Load, 12034MB/16106MB Physical, 17094MB/20247MB Page File, 4663MB/134217727MB Virtual
Screen Size: 1920 x 1080 (0 0 1920 1080), 1920 x 1200 (2400 -154 2400 1500)
Project Type: Python
Language: .py (Python)
Encoding: ACP (1252)
Installation Directory: C:\Program Files\SlickEdit Pro 27.0.1\ (non-removable drive,NTFS,296943MB free)
Configuration Directory: C:\Users\ebbek\Documents\My SlickEdit Config\27.0.1\ (non-removable drive,NTFS,296943MB free)
Migrated from: C:\Users\ebbek\Documents\My SlickEdit Config\27.0.0\
Hotfixes:
C:\Users\ebbek\Documents\My SlickEdit Config\27.0.1\hotfixes\hotfix_se2701_2_cumulative.zip Revision: 2   (currently loaded)
  • Hero Points: 151
Re: SE cannot find the python interpreter
« Reply #1 on: January 27, 2023, 03:11:58 pm »
Seems strange.  The checking code looks right, shouldn't be case sensitive on windows.
Did the message box really have a period at the end of the message?
What does it show in the "value" field if you go to Macro -> Set Macro Variable... and type def_python_exe_path into the "Variable" field?
ebbe
« Reply #2 on: January 27, 2023, 03:33:09 pm »
No, that period is one I accidentally added when I wrote the text.
The def_python_exe_path macro variable is: " C:\Python311\python.exe" which at first glance seems to be the python interpreter I want to use.
But note the space character at the front of the path string. Remove that and it all works.
  • Hero Points: 151
« Reply #3 on: January 27, 2023, 04:16:28 pm »
Ok.  I'll check the code that sets and accesses that to make sure it can't get set like that again, and I'll put it in the next hotfix.
Thanks for the report.
  • Hero Points: 151
« Reply #4 on: January 31, 2023, 04:02:16 pm »
I checked in a fix that should be in the next hotfix so that shouldn't be possible anymore.  And change the error dialog so the path is quoted, in case any other non-printable characters manage to get in there.   Thanks for the report.
ebbe
« Reply #5 on: February 01, 2023, 06:41:57 am »
Thank you.
