Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
When I use the command "hide-code-block",The "outline" of the file will be off
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: When I use the command "hide-code-block",The "outline" of the file will be off (Read 546 times)
Ciky_Yin
Community Member
Hero Points: 0
on:
February 21, 2023, 07:43:03 AM »
When I use the command "hide-code-block",The "outline" of the file will be off automatically.How to solve this problem?
Logged
SlickEdit Team Member
Senior Community Member
Hero Points: 530
Re: When I use the command "hide-code-block",The "outline" of the file will be off
Reply #1 on:
February 21, 2023, 02:51:36 PM »
Hide-code-block and outlining styles are not compatible. Outline styles do not necessarily represent a code block. Maybe we could add a command like hide-outline-block to collapse outline sections.
Logged
Hero Points: 517
Reply #2 on:
February 21, 2023, 04:15:09 PM »
If you are using outlining, you can use the "plusminus" command to collapse a code block (and uncollapse it). This does not interfere with outlining. It is bound by default to Ctrl+\ (backslash) in most emulations.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
