Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
How to disable popup saying to Ctrl+Click hyperlink
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How to disable popup saying to Ctrl+Click hyperlink (Read 250 times)
Senior Community Member
Hero Points: 132
on:
May 05, 2023, 01:16:46 pm »
In my code comments I often have a hyperlink,
http://something.com/etc
When the mouse hovers over it there is a popup that appears saying I can Ctrl+Click to go to the hyperlink.
How to disable this popup from appearing? It is obscuring some text I would like to see.
Thanks!
Logged
SlickEdit Team Member
Hero Points: 153
Re: How to disable popup saying to Ctrl+Click hyperlink
Reply #1 on:
May 05, 2023, 07:34:39 pm »
On the Options dialog you could go to Appearance>General and shut off Underline URLs.
Note:
Unfortunately, this will completely disable the ability to jump to the URL when you Ctrl+click on it.
Logged
Hero Points: 132
Reply #2 on:
May 05, 2023, 07:36:28 pm »
Thanks Dan! I don't need to jump to the URL so that is fine.
How to disable this using SlickC?
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
