Author Topic: Cursor problem in 27.0.2 hotfix5  (Read 523 times)
ahkevin
« on: June 08, 2023, 02:52:12 AM »
1. put cursor on a line.
2. scroll screen to make cursor invisible.
3. pressing key j/k(vim emulation) can't make cursor visible(It works in v27.0.1).
SlickEdit Pro 2022 (v27.0.2.0 64-bit Qt5)
Serial number: WB952830
License file: D:\SlickEdit\SlickEdit Pro 27.0.2\win\slickedit.lic
Build Date: April 25, 2023   (State file: June 1, 2023)
Emulation: Vim
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 62% Load, 20190MB/32431MB Physical, 29713MB/50095MB Page File, 5438MB/134217727MB Virtual
Screen Size: 1920 x 1080 (2560 364 1920 1080), 2560 x 1440 (0 0 2560 1440)
Project Type: Cpp
Language: .c (C/C++)
Encoding: UTF-8, no signature
Installation Directory: D:\SlickEdit\SlickEdit Pro 27.0.2\ (non-removable drive,NTFS,75306MB free)
Configuration Directory: C:\Users\kevin\Documents\My SlickEdit Config\27.0.2\ (non-removable drive,NTFS,49120MB free)
Migrated from: C:\Users\kevin\Documents\My SlickEdit Config\27.0.0\
Hotfixes:
C:\Users\kevin\Documents\My SlickEdit Config\27.0.2\hotfixes\hotfix_se2702_5_cumulative.zip Revision: 5   (currently loaded)
« Last Edit: June 09, 2023, 02:09:12 AM by ahkevin »
  • Hero Points: 515
Re: Cursor problem in 27.0.2 hotfix5
« Reply #1 on: June 09, 2023, 01:24:43 AM »
Reproduced. Looking into this
  • Hero Points: 515
« Reply #2 on: June 09, 2023, 02:22:04 PM »
This is not hot fixable. I'll need to build installers.
What platform(s) do you need?
ahkevin
« Reply #3 on: June 09, 2023, 11:18:53 PM »
OS: Windows 10 x64
thanks
  • Hero Points: 515
« Reply #4 on: June 10, 2023, 11:50:29 PM »
The fix is in this installer (includes up-to hot fix 5):
http://support.slickedit.com/outbound/2702/se_27000200_win64.msi
