Author Topic: Crash when opening "New File Dialog" (12.0.2.0)  (Read 10526 times)
John W.
« on: August 03, 2007, 07:11:39 AM »
When selecting File->New, SlickEdit crashes and shows the Slick-C Stack with the following Slick-C Error message:
Variable element or variable not initialized.
file=setupext. ex offset=1811
I've attached the vsstack file.
Any ideas to whats happening?
evanratt
  • Hero Points: 23
Re: Crash when opening "New File Dialog" (12.0.2.0)
« Reply #1 on: August 06, 2007, 08:22:18 PM »
Hi,
I was having the same problem when I went to the File Extension window and posted about it here:
http://community.slickedit.com/index.php?topic=1934.0
I ended up re-running the setup package and choosing Repair Installation, and then re-applying the latest hotfix, and my issue was fixed. Hope that might help you... Still wish I knew how I got into that state, though.
-Evan
John W.
« Reply #2 on: August 07, 2007, 06:51:01 AM »
Thanks Evanratt, this solved my problem.
I still have no idea to how or why it happened.
