Author Topic: SlickEdit 2023 (v28.0.0) - Now Available  (Read 1966 times)
Rodney
  • Hero Points: 54
« on: July 26, 2023, 10:54:21 PM »
Fixes, Features, and Enhancements in SlickEdit 2023 (28.0.0)
  • Block Matching (find matching paren)
    • Parenthesis, brace, and bracket matching uses a new high performance set of callbacks written in C++ (rather than Slick-C) for languages that support building a token list while parsing.
    • XML and HTML block matching has been rewritten in C++ for additional speed and also provides some new features.
    • Implemented advanced fast block matching for:
      • Assembly
      • Bourne Shell
      • C Shell
      • Erlang
      • Fortran
      • C# LINQ query expressions
      • Clojure
      • Common Lisp
      • M4
      • Modula-2
      • PowerShell
      • Rust
      • SQL (PL/SQL, Sybase, DB2, and ANSI)
      • Swift
  • New Languages Supported
    • Dockerfile
      • Color coding
    • Django
      • Add Django color coding to HTML or other languages.
    • Common Lisp
      • Color Coding
      • Symbol Navigation
      • Symbol Completion and List-Symbols
      • References
      • Statement Tagging
      • Auto Parameter Information
      • Docs for all Common Lisp builtins
      • Syntax Indent
      • Expand/Collapse Code Blocks
      • Advanced Paren Matching
      • Interactive Shell for SBCL
      • F1 API Help jumps to Lisp Hyperspec
  • Language Support Enhancements
    • All Languages
      • Added "Encoding for new files" option to language specific File Options. For example, you could set "Encoding for new files" for Plain Text (.txt) to "Utf-8" which includes a signature. The encoding for existing files isn't changed but new files you create would default to Utf-8 with a signature.
      • Added "Encoding" option to language specific File Options. The extension specific encoding option is still available in case you need more granularity.
      • Added new frameworks for fast block matching (find-matching-paren)
      • Added ability for language specific parsers to annotate the token list with block matching information
      • Added ability for block matching to recognize start, scope, and end positions of a symbol or statement as a block matching group.  Languages with a good statement parser, even they have no codified block matching intelligence will get good block matching using this technique.
    • CSS Enhancements
      • Inline color samples. Click on the sample color to change them.
    • HTML Enhancements
    • XML and HTML Enhancements
      • Smarter handling of XML and HTML self closing tags.  Typing <code>/</code> while in a tag will finish the self-closing tag.  Hitting space or enter between <code>/</code> and <code>></code> will expand the self-closing tag with a complete end tag.
      • Support for completion of entity names within HTML and XML attributes.
    • Scala Enhancements
      • Updated Scala debugger backend to improve performance and breakpoint handling.
    • Bourne Shell Enhancements
      • Improved color coding.
      • Implemented native Bourne Shell parser for tagging which has statement tagging support and also picks up locals and global variables.
    • C Shell Enhancements
      • Implemented native C Shell parser for tagging which has statement tagging support and also picks up locals and global variables.
    • PowerShell Enhancements
      • Implemented native PowerShell parser for tagging which has statement tagging support and also picks up locals and global variables.
      • Made numerous improvements to PowerShell syntax coloring for builtin functions and variables.
    • Clojure Enhancements
      • Added select-code-block support.
      • Symbol Completion for API Symbols
      • F1 API Help jumps to Clojure API pages
    • Windows Batch Enhancements
  • Tagging
    • Added new option (ON by default) to show brief comment summary for Auto-Complete and Function Parameter Info in order to save screen space
  • Version Control
    • Git
      • Diff Selection with most up to date
        • Select a group of lines to diff with Git.
        • User configurable ability to extend from the selection to the ends of the difference block.
        • User configurable ability number of matching lines required at the top and bottom of the difference block.
      • Added &quot;Go to GitHub for <repository name>&quot; to Version Control menu
  • Editor Window
    • Force-wrapped long lines now have a long line indicator drawn on the right side of the editor.
    • Added "Edit > Insert Unicode Char..." dialog (insert-unicode) for quick entry of Unicode characters.
    • Added delete-all-blank-lines command.
    • Fixes for a number of line oriented commands which needed to ignore the last line of empty char/stream selection.
  • Find and Replace
    • Improved granularity of items for color coding searches. For example, you can search for any String, single quoted strings, or backquoted strings.
    • Improved multi-file search and replace performance.
    • Added time elapsed for multi-file search or replace operations..
    • Now ` and ! can be used instead of / (slash) for command line search/replace (`find-me` or c`find-me`replace-with-me`). Using other separators requires a space between the command name and the search separator character (l $find-me$ or c $find-me$replace-with-me$)
  • General
    • Changed format of vrestore.slk to XML (vrestore.xml). It is fairly easy to make edits to vrestore.xml due to it's simplicity.
« Last Edit: October 31, 2023, 11:28:20 PM by Rodney »
