Author Topic: Backup failure  (Read 1091 times)
mjdechirico
Backup failure
« on: August 25, 2023, 07:54:13 PM »
While attempting go save an member I am getting the attached failure in Backup failure capture.jpg
SlickEdit Pro 2022 (v27.0.2.0 64-bit Qt5)
Serial number: WB953713
License file: C:\ProgramData\slickedit\27\slickedit.lic
Build Date: April 25, 2023
Emulation: ISPF
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 37% Load, 12097MB/32495MB Physical, 13976MB/65263MB Page File, 4692MB/134217727MB Virtual
Shell Information: C:\windows\system32\cmd.exe /q
Screen Size: 3440 x 1440 (0 0 3440 1440)
Language: .txt (Plain Text)
Encoding: ACP (1252)
Installation Directory: C:\Program Files\SlickEdit Pro 27.0.2\ (non-removable drive,NTFS,236952MB free)
Configuration Directory: C:\Users\MDeChirico\OneDrive - Micro Focus\Documents\My SlickEdit Config\27.0.2\ (non-removable drive,NTFS,236952MB free)
Migrated from: C:\Users\MDeChirico\OneDrive - Micro Focus\Documents\My SlickEdit Config\27.0.1\
  • Hero Points: 153
Re: Backup failure
« Reply #1 on: August 25, 2023, 08:57:38 PM »
If you go to Tools>Options, and expand "File Options", what is "Backup" set to?
mjdechirico
Re: Backup failure
« Reply #2 on: August 28, 2023, 02:28:56 PM »
See attachment please.
  • Hero Points: 153
Re: Backup failure
« Reply #3 on: August 28, 2023, 03:48:02 PM »
One way this can happen is if the buffer is changed from readonly to read/write by clicking on the indicator near the bottom right of the editor.  This would leave the file read only, but allow SlickEdit to attempt to write the file.  And this may give an erroneous error message.  Is there any chance this is what is going on?
mjdechirico
Re: Backup failure
« Reply #4 on: August 28, 2023, 03:55:40 PM »
Not as far as I know.
That being said, I deleted all traces of the member that was being edited when this was happening and the problem went away.
Also, I think that this was caused by something that my employer did to the pc, I will say no more about this.
Thanks for your help.
  • Hero Points: 153
Re: Backup failure
« Reply #5 on: August 28, 2023, 03:59:30 PM »
Can you retrieve that member through backup history?
mjdechirico
Re: Backup failure
« Reply #6 on: August 28, 2023, 09:16:32 PM »
Yes, all appears to be working properly now
