Author Topic: Beautify on non-main window applies to wrong buffer  (Read 1337 times)
astromme
« on: October 24, 2023, 09:14:08 PM »
SlickEdit Pro 2023 (v28.0.0.4 64-bit Qt5)
License type: Beta License
License expiration: 2023-11-09 17:00:00
License file: /opt/slickedit-pro2023beta4/bin/slickedit.lic
Build Date: October 16, 2023
Emulation: Brief
OS: Linux
OS Version: Ubuntu 22.04.3 LTS
Kernel Level: 6.2.0-060200-generic
Build Version: #202302191831 SMP PREEMPT_DYNAMIC Sun Feb 19 23:37:22 UTC 2023
I have two windows with several panes each.  I click on a pane in the non-main window to move focus there.  I then click Tools->Beautify->Beautify (My Default), but it applies the Beautify to the pane in the main window that takes focus when I first click the Tools menu.  I've noticed this often happens with many menu options when trying to apply these to a pane in the non-main window.
  • Hero Points: 544
Re: Beautify on non-main window applies to wrong buffer
« Reply #1 on: October 24, 2023, 11:18:19 PM »
This is a limitation. We weren't able to make this work on Linux. You can see how the focus immediately changes focus to a main MDI window document tab when you click on a drop down menu. As a work around, you can bind that command to a key , add it to the right click context menu, or invoke from the command line.
