Author Topic: Slick-C Error when opening "File Extension Setup" dialog  (Read 8062 times)
evanratt
  • Hero Points: 23
« on: August 06, 2007, 04:36:59 PM »
Since installing hotfix revision 10 for Slick 12.0.2 (it still happens with revision 11), when I try to go to the File Extension Setup dialog I get a Slick-C Error: "Invalid argument    file=setupext.ex   offset=14531". Any ideas on how to fix this? The Slick-C stack trace follows. Thanks!
-Evan
Slick-C Stack:
Invalid argument
setupext.ex 14531 _ext_form._extension.\x{d57}(1)   p_window_id: 124   p_object: OI_COMBO_BOX   p_name: ctlencoding
combobox.ex 3614 static(0)   p_window_id: 42   p_object: OI_LIST_BOX   p_name:
combobox.ex 2742 static()   p_window_id: 39   p_object: OI_COMBO_BOX   p_name: _extension
combobox.ex 2438 _ul2_combobx.\x{fa}()   p_window_id: 39   p_object: OI_COMBO_BOX   p_name: _extension
evanratt
  • Hero Points: 23
Re: Slick-C Error when opening "File Extension Setup" dialog
« Reply #1 on: August 06, 2007, 08:07:47 PM »
I ended up rerunning the setup package and repairing the installation, and it's working fine now. Something must have gotten corrupt in there, somewhere.
John W.
« Reply #2 on: August 07, 2007, 06:42:39 AM »
Thanks Evanratt, this solved my problem. Still no clue to what was wrong.
