Author Topic: SlickEdit thinks Rust attributes start open a clause  (Read 1810 times)
spongyryno
« on: April 14, 2024, 12:48:24 PM »
Open a new Rust file in SlickEdit (such as "foo.rs"), and type in an attribute, such as:
#[allow(dead_code)]
Now, at the end of the line, hit <ENTER>. You should be in column 1, the same column as the #.
But you're not... you're indented one tab. Why?
  • Hero Points: 535
Re: SlickEdit thinks Rust attributes start open a clause
« Reply #1 on: April 14, 2024, 01:15:08 PM »
We will look into this
  • Hero Points: 535
« Reply #2 on: April 14, 2024, 04:16:52 PM »
A hot fix is available for this.
Download the hot fix here:
https://www.slickedit.com/hotfixes
Then load the hot fix: Help>Product Updates>Load Hot Fix...
spongyryno
« Reply #3 on: April 14, 2024, 06:53:35 PM »
The name of that hotfix appears to be "hotfix_se2802_3_cumulative.zip".
However, when I try to apply it, I get:
SlickEdit Pro
Invalid hot fix version:
The selected hot fix is for SlickEdit 28.0.2.0.
You are currently running 28.0.1.0.
However, the "cumulative" implies it should apply to 28.0.1.0 as well. Regardless, I cannot find any other hotfixes, much less one for 28.0.1.0.
  • Hero Points: 535
« Reply #4 on: April 14, 2024, 09:19:22 PM »
You need to download and install SlickEdit 28.0.2 and then install this hot fix
All 28.0.1 hot fixes are already in SlickEdit 28.0.2 which also includes other fixes.
« Last Edit: April 14, 2024, 09:51:53 PM by Clark »
spongyryno
« Reply #5 on: April 14, 2024, 09:54:23 PM »
Okay, I got the hotfix loaded.
That fixes:
#[allow(dead_code)]
...but not:
#![allow(dead_code)]
(Note the "!" in the 2nd column, indicating this atttribute applies globally instead of locally).
  • Hero Points: 535
« Reply #6 on: April 14, 2024, 10:57:03 PM »
Added a hot fix for this too. You can download it now.
spongyryno
« Reply #7 on: April 15, 2024, 11:07:50 PM »
Thanks, Clark. With the latest hotfix, despite my best efforts, I haven't been able to find out a new way to break it.  ;D
  • Hero Points: 535
« Reply #8 on: April 15, 2024, 11:44:28 PM »
Thanks for posting about these issues.
